TwinTurbo.NET: Nissan 300ZX forum - Re: code 42
Subject Re: code 42
Posted by Tuner_Dev on September 05, 2013 at 12:29 PM
  This message has been viewed 197 times.
In Reply To code 42 posted by Medallion Man on September 05, 2013 at 08:32 AM
Message cool thanks for that. ill look into the fuel temp sensor/harness today. also yea you are right, the high idle was most likely due to the wrong adjustment on the tb linkage. i messed around with it last night and adjusted the little bumper screws to make sure its right. also adjust the tps. started up last night and its idling nicely. about to go out today to set idle some more and check if the pcv valves fixed the smoking.
